Results 1 to 10 of 21
Thread: upside down steering?
    Eltham, Melbourne
    G'day all, i just want to make sure i got the right idea here. I am
    98 percent sure i have a 1962 Series 2a...
    I've just had the leaf springs replaced and now my steering arms hit the springs, i'll put up a pick.
    From what i understand the steering arms on a series 2 are positioned over the axle but are underneath on a 2a?
    Is the steering just upside down on my car?
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    I havn't seen a series 2 steering setup, but to me your steering arm is upside down
    Both on our county and disco's they sit the otherway up
    Yep i think they are upside down
    CHEERS TIM.
    Stockton, NSW
    May 2008
    Bundaberg Qld
    2A steering arms come out from under the hub (S3 as well). My first question would be;
    is yours a 2A ?
    if so, has it had a front diff swapped sometime in it's life ?
    Paul
    Threads merged.
    Eltham, Melbourne
    I wondered if you could merge the threads or delete one or smth?
    I'm almost certain its a 2a! is there a way of looking up the vin number to find out for sure? the springs are the same on all the models i think? I've only had the it for 3 years so it could be possilbe that the
    last owner made some changes.
    It seems an odd mistake to make to put the steering arm on upside down?
    even then if i do put it on the bottom of the axle the holes for the tie rod ends will be the other way around, i'm trying to picture it as the back bar is longer than the front.. do i make any sense?
    May 2008
    Bundaberg Qld
    Ron - thanks
    Andwoo, post up your chassis number and a vehilce pic. I'm sure someone will be able to help. I don't think it is as simple as just swapping steering arms from the bottom to top.
    Paul
    Eltham, Melbourne
    I was hoping it would be that easy but i think your right.
    The Vin no. is 143101051 and heres a pick of my boy
    Thankyou for your help
    May 2008
    Bundaberg Qld
    Andwoo
    It is a 1961 model S2, the 4th digit in the number indicates year (8 for 58, 9 -59, 0-60, 1-61 for the series 2's). So the steering arms should be coming from the top of the hubs. I am still really new at this stuff too, so I can not offer any advice on the fixit side of things.
    On the bright side (for me anyway), this is my first technical assist, so I am pretty chuffed that I could help someone (you) as others have helped me.
    Paul
    Eltham, Melbourne
    Thankyou Paul, your a good egg in my books! Aulro has proved to be a real asset for infomation.
    You know only a few weeks ago i thought mine was a 1963 series 2, till i was told that if it was a 63 it was a 2a. But now i learn its a 1961 s2!!!!
    Damn it you know maybe i got the wrong springs in it? seemings i thought it was a 2a...
