The bearings are as cheap as chips from any bearing supplier. Do a search on the forum, you'll finds all the generic numbers.
Mine crapped themselves in the front end ....
I have pulled the drivers side apart and they are discintergrated , so i call STATEWIDE Bearings .... no listings for Land Rovers
I ring the Stealers ... $245 front set
I ring Rova Craft ... but the guy Ian had only series listed ones he quoted me on
So is there a listed part number someone can help me out with please ???
timkin LM603011, have a close look around the edge of your old bearing, you should see a number
Land rover part number RTC 3429
are they all the same ? inner and outers ???
There are no numbers on my shells , they are scrap iron now in mulitple pieces
thanx so much WEEDS
yes, all the same 'inner/outer/front/rear, tdi through to td5
 Master
						Master
						if your stuck and can't get any then i have a pair here you can have for rovacraft money (that's where i got them from) and i'll put off doing my rear ones till they get more in.
Timken numbers for all wheel bearing on rangy Classic / defender
LM603049
LM603011
2 of each
And seal is a 60 x 80 x 8 double lip seal
Ian
Sith, the seals to use to prevent any water entering the hubs AGAIN are RTC3511
JC
