Originally Posted by
peterg1001
I have the chassis, shackles and springs all separated. I need to bolt the springs back onto the chassis. I have 12 shackle bolts as follows:
4 long bolts
4 short bolts with long threads
4 short bolts with short threads
Can anyone tell me which bolts go where?
Thanks in advance, Peter
4 long bolts - rear end of front springs, both ends of shackles; chassis is wider than springs, one shackle plate has lump on it to take up the space.
4 short bolts with long threads - rear end of rear springs: long thread screws into both shackle and nut.
4 short bolts with short threads - front of all four springs; goes through spring hanger and only screws into nut.
If replacing any of them remember that there are two types, BSF and UNF, and you have to get the ones that fit your shackle plates or replace these.
I think I got it right from memory!
