Results 1 to 10 of 17
Thread: Drawer Sliders
    Jan 2009
    On the road around Australia
    Drawer Sliders
    Hey all,
    after a few visits to ARB and seeing the exorbitant prices that they charge for their storage drawer systems, I plan to make my own. The actual construction I have no problem with, but I'm not sure where I can source a set of heavy duty drawer slides for them once they are built. I've checked out fleabay, but they are still in the +$120 price range for anything that extends more than 500mm.
    Seeing as I'm far from being the first guy to build a set of rear drawers, does anyone out there know where I can pick a set of sliders up for a reasonable price??
    Kippa Ring
    Cant tell where you are from, but if in Brisbane try Universal Engineers Supplies at Virginia.
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    95 Disco v8 - The Next Victim
    May 2002
    Heathcote (in "The Shire")
    Have a look at http://hettich.com.au and search for their drawer slides
    The slides seem to start at around 5.82 in the catalogue up to 70kg ratings (couldn't see the ones I used - but didn't spend a heap of time looking)
    Martyn
    SW of Geelong
    These ones take up to 90kg >>>>>>>> 90kg Runners
    I'm a cabinet maker, so I'm quite familiar with drawer runners. These runners were not intended for use in vehicles, but they are commonly used for 4x4 drawer systems, including myself. They will do a good job, but they wont last forever. The main problem I've found is, they do not like dust because they have pretty small ball bearings and they're pre-greased which tends to attract the dust.
    Hafele have runners up to 227kg >>>>>> 227kg Runners, but I wouldn't expect any of the heavy duty ones to be cheap.
    Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Dayboro, Qld
    I recently purchased a set off ebay, 750mm roller bearing type that are rated at 90kg. I'm sure they were $82 delivered. I've got the guys card with his details, so I'll dig it out and post his details on here.
    I looked at the same thing locally for $200 +
    I've also made my own drawer system/storage units out of flooring grade chipboard. The runners are excellent
    Tangambalanga
    Hi guys,
    Has anyone got pics of their setup so we can check this out in a bit more detail,,
    I've seen plain bearings just bolted in a line along the side panels, top and bottom to accomadate a section of small RHS on the side of the draw. This seemed to look really strong and robust, ready to take the sort of pounding in the back of 4x4.
    Chops
    buddha D2 Guest
    Made a fridge slide with these..
    eBay Seller: devon annie: Cars, Bikes, Boats, Home items on eBay Australia
    Bought some of these for a fridge slide in home made storage unit for my D2.....good and strong with a full open locking position.
    AG
    Oct 2008
    Moved to Mallee/ Wimmera area in 2010
    Where to get drawer runners
    Hafele, Hettich and Blum are the best in the cabinet industry and have a life time warranty, I highly recommend them. The Hettich I think go to 1000mm long but are $200 a pair for under mounts like the old kitchen drawers but way way better.
    Most rear drawer systems are side mounts but I dont know if they are stronger than the super strong under mount runners although side mounts are generally much cheaper.
    Where are you? There is a company called "Nover" in most eastern board states which sell Hettich or search local directories. Dont buy cheap unbranded as it will let you down by having bearing failure.
    Hope this helps
    Jan 2009
    Sorry - I thought my location was in my profile. I'm in Adelaide at the moment. I checked out Hafele, and they seem to have a location in Adelaide, so I might pay them a visit.
    Oct 2008
    I didnt use Hafele much, what I did use was very good quality hardware.
