Results 1 to 10 of 20
Thread: 265/75/16's on disco rims
    Feb 2005
    anybody running this combo on a defender?
    apart from adjusting steering stops any other rubbing issues?
    does reversing/flipping the centres help out?
    need a new set of rubber for an outback trip next year more than likely will be bfg m/t's
    235/85/16's or 265/75/16's will only need to buy 4
    255/85/16's should buy buy 5/6
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    if your towing anything stick with the 235's IMHO
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    i'd say you'd need to reverse and flip the centres of the disco rims, we had 235/85/16's on the county with d1 rims, they rubbed abit on the radious arms, seeing 265/75/16's are alot wider i'd say they would rub a fair bit
    Not 100% shore though.
    CHEERS TIM.
    Feb 2005
    Quote Originally Posted by incisor View Post
    265/75 are the same rolling diameter....yes/no and yes i do a bit of towing that why i'm not too keen on 255/85
    Mar 2007
    Bulimba
    I had that combination on my 110 when I first got it, but had issues with fouling the suspension arms, no great surprise seeing as the extra width is inboard of the centreline and the offset is different (to suit the Disco). I now run 235/85 16 (Coopers) on 130 (wolf) rims and have full lock, predictable steering and good handling. Also 5 less modified parts if you find yourself stranded in 'kickatinalong' with a bent rim.
    Logan Village area S.E. QLD
    weeds our 245 75R16 which we run on the disco was way to big on the fender
    scrubbed all the time
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Feb 2005
    Quote Originally Posted by long stroke View Post
    i figured i would have to adjust the steering stops, would just mean i would have the turning circle of a 130
    Quote Originally Posted by Red October View Post
    Quote Originally Posted by The ho har's View Post
    i'm guessing steering arms
    i was more interested in body work shock towers
    looks like i might stick with 235/85/16's....after all she is a tourer
    265's
    Rims are the same offset as std defender rims so there should be no problems there for your deefer.
    I have run 265's on the std boost alloys(same offset as disco steel rims and there was no noticeable rubbing, only just on the radius arms on full lock off road.. but very rarely if at all.
    all in all there should be no issues. if you want to get the disco rims offset more then and additional 25mm works nice and still leaves the tyres covered.
    Giles
    Camp Hill Queensland
    I've done it before. Mild scrubbing on the top of the rear spring locating lip on full articulation. Quite liveable
    '95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
    '85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
    '76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
    Gold Coast, QLD
    I have 265/75-16's as well, does rub a bit on steering lock but no biggie, slight offset will help though.
    What i do find is that they ride quite a bit "softer" than the 235's i had on previously, just makes it more comfy in the fender.
    Next set and i'll be tempted to go 255's - skinnier and taller is the go for my fender
    Louis
    '99 'fender - it goes... (quite well actually!)
