O.A.T. Coolant replacement for Td5
This thread is really started as a summary of the thread another OAT coolant brand
The Td5 Disco/Defender manuals stipulates you use an O.A.T. coolant. Use Havoline Extended Life Coolant (XLC), or any ethylene glycol based anti-freeze (containing no methanol) with only Organic Acid Technology corrosion inhibitors, to protect the cooling system
As many know this isn't a readily available product and so we have to hunt around for a suitable alternative. The simple answer is CAT ELC (part no. 129-2151) or Caltex ELC.
The following is a summary of what I have uncovered regarding the elusive O.A.T. coolant.
Havoline XLC is manufactured by Texaco-Chevron
Caltex ELC is manufactured by Texaco-Chevron and can be substituted for CAT ELC.
In otherwords they are one and the same.
This links to the web site for Caltex ELC
Now in my case I could access the CAT ELC ($92 for 20L drum of Premix 50/50) without incurrring additional freight costs. The Caltex ELC should also be available to you and both are available in premix or concentrate form.
I hope this helps answer a few questions. Coolants aren't all the same, but there are also not that many varieties as you might think.
Reason: Updated Caltex ELC link
