Thread: Where's that bird???
    Aug 2008
    Launceston Tasmania
    Today a work mate called me up on the uhf as i passed him and asked what sort of bird id hit??? last night i developed a strange squeak that seems to come from the gearbox/transfer??? it only happens going forward in gear. no noise with the clutch in or just free wheeling or in reverse?????? its got me puzzled.
    i replaced all oils about 6 weeks ago and theres been no leaks so i don't think low/out of oil is the issue.
    any help appreciated.
    Douglas Park, NSW
    Dry propshaft uni?
    Aug 2008
    Launceston Tasmania
    will get to the workshop early in the morning and give it all a good grease.
    but wouldn't that still make a noise no matter the clutch???
    Nov 2007
    Had the same in my disco the other day. Shaft that enters gearbox was worn, apparently has a cast iron bit that can disintergrate, was told I was lucky I replaced when I did other wise the gear box........
    Douglas Park, NSW
    Depends. Some can make a noise while under load, others can be noisy just when slowing down.
    The universals would be the first & easiest to check though.
    Is it a Td5? If so, it could be the common exhaust manifold leak at the head. Check the rear stud & see if it's still there.
    Aug 2008
    Launceston Tasmania
    All greased up and no noise now. thanks for the help.
    i didn't think the unis would need more grease as they were only done about 2 months ago. but then its in mud and water almost every day lately.
    Douglas Park, NSW
    I grease mine after every trip that involves water. Mine's not an every day car though so maybe every week or so might be an idea if you're in water regularly.
