I used a pair from Four Wheel Drives and they fitted OK.
They came sealed in a plastic bag inside a cardboard box, FWD's carefully removed them from the boxes and just gave me the collars in the plastic bags. I guess the manufacturers details were on the box and they didn't want me to see this.
Only one size (not stated) was available so it either fits OK or it doesn't. Also had to polish the surface where the seal runs because as supplied it looked like the seal would be quickly damaged by the rough finish.
It would make sense to get a batch made locally but the ID would have to be matched to each axle to get the correct interference fit and the correct grade/hardness of steel used.
The other solution is to do what the previous owner had done to mine, weld the old collars back in place
I used a 20T press to press the collars on but had to grind through & split the originals (once the weld had been ground off), some pictures are in this thread Getting the Series 1 Ready for Cooma
The bearing is readily available (Mike, I was also told it's an F100 wheel bearing) from any bearing shop. I have the bearing number at home if anyone needs it.
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
