Results 1 to 6 of 6
Thread: A Q re switches
    Bracken Ridge, Qld
    A Q re switches
    What's the application of the
    On-On: £7.00 (each)Single Pole ON-ON switch for 2-way operation of accessories with their own switched facility.
    as per halfway down the page
    MUDSTUFF.CO.UK, Carling Technologies Switches, Land Rover Defender Solutions: West Yorkshire
    Would this be the type of swtch you'd use for, say, a worklight where you had an in-cab switch and a rear of the truck switch. Switching the switch would turn the light to the opposite state (eg if it was off, to on, if on, to off) ? Make sense ? Am I on the right track ?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Central Queensland
    not being able to see the pinout of the switch too clearly, i'd say it functions as a changeover switch, ie: up is on from inside the cabin, down is switched from outside the cabin
    Adelaide SA
    Quote Originally Posted by Sprint View Post
    Yep...
    Up turns your light on regardless, say for reversing. Down moves the on / off function to a second switch mounted on the light.
    Bracken Ridge, Qld
    Well thats no use if its ON and I'm inside the cabin I can;t turn the damn thing off ! (assuming its "on" on the light itself).
    gone
    1996 Discovery 1
    current
    Central Queensland
    either leave the external light switch off, or get an on-off-on 3 position switch
    its commonly used inside the vehicle so that the power feed for something like your reversing light can get its power from one of 2 sources one being switched and the other being permanant.
    I have a similar (but cheaper) switch in fozzy driving the rear work light. In one position it runs with the reverse lights in the other it connects direct to battery and I can turn the light on or off with the switch on the back of the light. of course if I turn the light off with the switch on the back of the light It wont turn on with the reverse lights untill I realise that Ive left the switch on the light off, get out, turn it on, get back in and select reverse again.
