Results 1 to 10 of 13
Thread: guages
    Jul 2008
    guages
    thinking about getting some guages would like
    boost
    egt
    trans temp
    the reason i like the thought of them is to keep my eye on things specially egt and trans temp what are your thoughts are they worth it where would you mount them in a d1 300tdi
    Back down the hill.
    Quote Originally Posted by disco_mitch View Post
    boost
    egt
    trans temp
    You can get a tidy matching pod that mounts on top of the dash.
    Jul 2008
    i was thinking a few pvc 90 corners and mount them down the bottom of the pillar but i guess my question is are these guages really used that much
    JohnR Guest
    Google Mud Stuff. They have a great pod the mini one that would easily hold 3 gauges. Their nice and easy to deal with.
    Hi mate,
    Take a look at www.nata.net.au!
    I can get you MUD stuff too!
    The entertainer
    Back down the hill.
    Only you can answer that
    Jock The Rock Guest
    Hey mate I have a Defender with the same motor
    I have a TM-2 (head temperature), EGT and a Boost Gauge
    The first two are a must I reckon, I also have an Engine Saver (Low coolant alarm)
    If you have fiddled with your fuel pump then a EGT is a must, I was once told never to run a Tdi anywhere over 700 degrees. Occasionally I hit 600 or so and know I need to start backing off on the loud pedal
    The boost gauge was fitted by the fella who owned the Landy before me. I would have to say I don't think I'd get one. I'm not really sure of the point, fair enough it's interesting to watch but what else do you do with it?
    Head temperature is good for if you thermostat doesn't open
    My EGT is a Thermoguard unit, sold by a member on this forum
    The TM-2 and Engine saver I sourced from Davy on this forum again another great bloke to deal with
    Jul 2008
    Quote Originally Posted by Jock The Rock View Post
    if you dont mind me asking how much did they set you back
    as for the auto would a oil temp guage work or is a auto temp guage different
    MARS 2.5 INCH KRT-250OT 28MM SLIM OIL TEMPERATURE GAUGE - eBay Temperature, Gauges, Car Parts, Accessories, Cars, Bikes, Boats. (end time 16-Aug-09 21:07:16 AEST)
    Jock The Rock Guest
    Here's the EGT - $265
    ThermoGuard Instruments
    I'm not sure whether Davy is still doing the combo but I imagine he is
    http://www.aulro.com/afvb/verandah/6...ure-alarm.html
    Sorry mate not sure about the trans sensors
    Rangier Rover Guest
    Boost/EGT combo.
    Have dug this up rather than start another thread.
    Been looking for a combo boost/pyro that would suit my other ride as want to integrate it into the dash.
    Have found these... May interest some of you.
    Colored Digital Boost Gauges - McNally Electronics
    http://i293.photobucket.com/albums/m..._egt_gauge.jpg
    http://i293.photobucket.com/albums/m...rRover/red.jpg
