Results 1 to 10 of 12
Thread: Two questions
    Sussex Inlet. N.S.W.
    Two questions
    OK all those driving a 110 TDI. When stationary, where does your speedo needle point to? Does it read "0" on the dial or sit somewhere above it? Also I have just had new tyres fitted (the recomended size) and the darn speedo still reads 5k/h high) Do I have a problem or is this normal? Is there a fix? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Brisbane, South of the River
    Gday Jim
    My 110 speedo sits about o but does bounce a little on idle, interesting your speedo reads over, mine reads under by 9km/hr. Cant help with a fix though.
    Good luck.
    Ben
    South East Tasmania
    The speedo in my Defe was calibrated last January by a instrument and VDO specialist.
    It sit about 2 mm above the bottom line (0 reading) and does not bounce.
    I have the standard tyres fitted on it.
    dmdigital's Avatar
    Standard tyres fitted and it bounces a little when travelling but sits on zero at idle. As for accuracy mine reads about 5% above the true speed.
    smurf village
    standard tyrs but reads 5km/h high sit on 0 when at idle
    Alice Springs
    I've owned four Defenders and their speedos all over-read by 5-10%. My current Tdi 130 over-reads by about 10%. I've checked it with a GPS. 235/85x16 tyres.
    Two questions
    Thanks for the answers all. My needle sits on around 5k/h on idle and if I tap the speedo it will drop back to "0". Maybe the mechanism is dirty or something. Perhaps I should just put up with it as it seems "normal" for a fender.
    Jim VK2MAD
    '17 Isuzu D-Max
    Aug 2009
    Bowenville, Qld
    My old boy has a 130 thats pretty far out by gps, 100k on the gps is about 118 on the speedo, i also have a navara at the moment(my 110 is on a boat over here new 2010 mod) its also out by the gps. 108kl=100 on the gps. took it back into the shop told them about the how they read differently, they said because it less then 10% they can't fix it. spose that just another reason why i traded it.
    Mar 2009
    Derbyshire UK
    All vehicles have speedo's that read 5/10 kph/mph fast.
    Quote Originally Posted by Grockle View Post
    except for mine..it reads spot on
    but I have had my tyres changed....I actually have to be carefull now going through the speed cameras
