Let me guess....it was the bolt closest to the firewall and the rattle was at about 2500 rpm
You'd think by now that LR would have broken out its precious supply of loktite to fix this not uncommon fault.
Thanks for the heads up.
 Wizard
						Wizard
						 Death Rattle
 Death Rattle
		Coming home from hell today ( work ) new noise!!!!!!!!!!!!!! Thought it may be turbo but son and receiver of all I own when I go, and Subaru wiz Kid, said heat shroud. Sure as, the bolt had rattled out of the mount . Worth a check, sounded like a death rattle.
Allan
Mahn England
Ex 300Tdi Disco:
 Wizard
						Wizard
						Thats the one. I would have thought they would check all fittings/bolts at service considering what they charge. But.....
Allan
Wouldn't be this bolt by any chance......
As far a Land Rover chasing up common faults and trying to rectify them, whats the old saying, "you can lead a horse to water....."
 Wizard
						Wizard
						Again thats the one. I have decided to spend a day tightening all bolts, nuts, screws etc myself!
Allan
Allan,
Don't forget top check the sway bar links, I have had 2 out of 2 130's with VERY loose ones, 1 had even dropped out
So much for PD....
JC
