Does the fuel filter need replacing?
Is the water sensor electrical plug connected at the bottom of the filter? If not, has the filter been drained to ensure there's no water?
There has been more than 1 instance where the pipe fittings were reconnected incorrectly to the pump after replacement but I cannot remember exactly what problems that caused.
Is the connector at the ecu still clean after replacing the injector harness?
