Correct, there is no pump in the fuel tank on the L series diesel FL1.
You'll find the fuel cut off solenoid located on the fuel injection pump - its on top of the high pressure head part of the pump (the part that has the 4 high pressure lines that go to your injectors). You'll see the solenoid unit with a wire running to it - it unscrews to visually check and/or you can run 12v to it and hear it click open. Be careful taking it off as it has a little spring in there.
FL1 fuel injection pumps very rarely go wrong - but in worst case scenario and it is dead it isn't necessarily all that expesive to replace if you source a used one from the UK (ebay.co.uk for eg) More likely to be one of the numerous sensors that it needs to run correctly and best way to determine that is to get its codes read unfortunately.
edit: a new fuel filter can't hurt either
