27th August 2009, 10:48 PM
Raised Air intake/ Snorkel
Hello,
Is there one that can be fitted to the 4.4V8. the ones ive seen advertised are for the 2.7TD (land rover & others). From a quick look, I cant see that the side air vent differs from engine model to engine model.
28th August 2009, 11:19 AM
The LR OEM RAI will fit all engines but the Safari snorkel will only fit the TDV6 ( I think the airbox is different)
The RAI is not a snorkel though as it is not sealed.
28th August 2009, 03:35 PM
The LR RAI can, however, be sealed.
28th August 2009, 03:54 PM
#4
Only if you also replace the fabric hose section to the air box and fill the holes in the rubber corner section.
See:
http://www.disco3.co.uk/forum/topic14190.html
