Results 1 to 4 of 4
Thread: L322 Glovebox / CD Changer Removal
    Nov 2008
    Central Coast, NSW
    I am in the process of removing the Glovebox to get access to the CD Changer which has a CD jammed in it. What a shocking job! Why they couldn't just put the two screws holding the changer casing on the front I don't know.
    Problem is, having followed all the instructions from the LR installation guide to release the glovebox, it won't move - seems very solid. Anyone else done this job? Help needed.
    With thanks
    davros9
    Douglas Park, NSW
    I'm not sure if this will help, you might have this info already. I do know that it is a PITA type job though.
    Remove
    1. Remove upper finisher.
      *** 76.46.12 Finisher - upper - drivers side ***
    2. Remove lower finisher.
      *** 76.46.14 Finisher - lower - passengers side ***
    3. Remove 2 Torx screws securing glove box from underside of fascia.
    4. Open glove box.
    5. Remove 5 Torx screws securing glove box.
    6. Disconnect multiplug from lamp.
    7. Release cable from glove box latch.
    8. If fitted: Remove 2 Torx screws securing CD multi-changer to glove box.
    9. If fitted: Withdraw CD multi-changer from glove box and disconnect link lead and both multiplugs. Remove the CD multi-changer.
    10. Remove glove box assembly.
    Nov 2008
    Central Coast, NSW
    Thanks Scouse
    It was the two screws mentioned in instruction 3 on your list - missed them at first.
