Results 1 to 3 of 3
Thread: Tutorial for putting a picture in your posts
    Jan 2009
    Gold Coast home of Maxi Drive
    First you will need to know where your picture is located on your computer.
    At this stage I will assume you know where to look for the picture you want to display.
    You need to upload the picture to a web site first.
    I recommend using http://tinypic.com/
    If you open up Internet explorer and type in http://tinypic.com/ at the top, it will take you straight to the front page of there website which should look like the picture below.
    Refer to the picture above
    Click on the "browse" and select the picture you want to upload.
    Then select "Upload Now"
    you will then get a message saying something like "uploading please wait"
    After the picture has uploaded to there website you should see it look something similar to this picture below
    Then left mouse click "Once" in the second box down. The Text in that box should then be highlighted black. see below
    Now you to RIGHT mouse click in the same box then select "copy"
    See below
    Now all you need to do is RIGHT click in the part of your ULRO post you want it to appear and select "PASTE". In you post it should look something like this
    Picture below
    That's all Folks. If you still can't do it I can't help you sorry!
    If now you can do it let me know I'd be Chuffed.
    There is also one as a Sticky in the AULRO General Chat area - it's been there for nearly 4 years.
    See http://www.aulro.com/afvb/general-ch...tos-forum.html
    Jan 2009
    I overlooked that. **** it took me a while to do it too, Bugger!
