are those numbers from The Good Oil davros?
Help! Got a few part numbers here I need clarifying!
Can people confirm for me these Hardy Spicer part #s?:
K5-A757 = front prop front uni joint and rear prop front uni joint
Is this also the one for the front hookes joint ("Double Cardan")? Why am I seeing on this forum referal to a K5-A747? I suspect Piddler had a boeing 747 fly over while they wrote and they should have written 757?
Also, is the bearing in the center of the hookes joint an SCV082B? Bloke at HS says they only list an SVC-82B...
Thanks for advice!
Oh! I just noticed that the part # on the box pictured in the thread
http://www.aulro.com/afvb/discovery-...problem-9.html
is SVC-82B not SVC082B so that solves that, but then saw another issue - one bearing had a dust seal supplied, one didn't. Should they come with one or not?
1974 Military Lightweight Landy --- Some dementia at 50 years old
2000 Disco series 2 now sadly moved on!
No5 Trailer joined the fold... Awaiting graduation to road licensed!
2021 Mazda BT50 or is that DMax?
'97 to '07. sold.![]()
They're all from the link I've edited into my post above - under pinnacles---discovery two
