Does it have a load knock when you start it without your foot on the clutch? because it sound like mine did before they fitted the modified clutch. The dealer said its clutch springs. hope this helps
Allan
 Master
						Supporter
						Master
						Supporterdoes anyone have the same sound from driveline and if so what could it be?
Level surface, engine and gear oil warm, idle revs from stationary in 2'nd low range.
[ame=http://smg.photobucket.com/albums/v427/Landy1973/?action=view¤t=GearboxNoise.flv][/ame]
Defender Kalahari 2006 (300 TDi)
2008 Puma 110 - sold
1973 Ser III 109" - sold
 Wizard
						Wizard
Allan
Sounds like my 110 did before the clutch was replaced. Here's the TSB:
LTB00166
Subject/Concern: Clutch Noise/Poor Selection
Models:
Defender (LD) 2.4 Puma Diesel Engine. 2.4 Puma Diesel Engine. VIN-range: 7A732615-9A766150
Markets: All
Section: 308-00
Summary:
Potential difficult gear selection and noise in clutch operation.
Cause: Improvements have been made to the specification of the clutch plate and clutch cover to
address both the potentially difficult gear selection and noise during clutch operation
concerns.Suggested customer concern code P24.
Action: Should it become necessary to install the clutch kit assembly, refer to the new procedure
detailed in Global Technical Reference GTR Workshop Manual, section 308-00.
Parts Required:
Description Part Number Quantity
Clutch kit Assembly. URB500080 1
Labour Time:
Operation Description Operation No. Time
Clutch kit Assembly Renew. 33.10.01 3.9 hours
Repair/Claim Coding:
Causal Part: URB500080
ACES Condition
Code:
Tim
 Master
						Supporter
						Master
						SupporterI suspect then the modified clutch has also expired then. My new clutch fitted some time back already
I'm on my second replacement clutch also CapeLandy, I think there has been another revision of the clutch assembly. To be honest my first replacement clutch was not much better than the original with its rattle.
Part number for the re-revised clutch is LR012199.
Tim
 Wizard
						Wizard
						Mine is very good, had to wait two weeks for it ( ex UK) but all good thus far
Allan
 Master
						Supporter
						Master
						SupporterThe kit that I had fitted in 05/09/2008 was LURB500080
 Wizard
						Wizard
						I have no idea of what part no it was but it changed my SVX from an E Bay auction to my wifes next car (After my passing)
Allan
