Results 1 to 10 of 21
Thread: NGK spark plugs
    May 2008
    NGK spark plugs
    About to put the heads back on the Rangie
    Went to local autopro and bought some new spark plugs. The bloke looked up the car in his book and brought out some NGK PFR5G-11 "Laser Platinum Premium" @ $26 each!! I bought them anyway.
    Just looking up the application guides to confirm gap should be 0.9mm for these plugs and can't find the P38A listed.
    Anyone had any experience with these plugs on a P38A?
    Paul.
    May 2008
    funny thing just happened... removed one of the old plugs from the old heads and it was a NGK PFR5G-11.
    I can answer my own question now...
    Still, your good/bad experiences with these plugs are welcome.
    richard4u2 Guest
    arent these the ones you not suppose to alter the gap on , read it some where
    Oct 2008
    Dunsandel, NZ
    Paul,
    Went to the NGK website. 1.1mm is the gap to set it to. Have a look in the spark plug settings on Rave and see what it recommends. Hopefully should be about the same.
    I did the same for my RRC, and it came up the same as the workshop manual.
    Chris
    G'day Paul
    If you try and alter the gap you're in danger of stuffing the precious metal layer on the electrode. The factory-set 1.1mm gap should be fine given the output from the coils.
    suggestion: buy some dielectric grease and (sparingly) smear it around the sp's insulator prior to refitting the boot. The grease will make it easier to replace the boot and act as a sealant from moisture etc. It also reduces flashing and voltage leakage from the plug.
    Super-not-so-cheap sell ?permatex brand dielectric grease in a tiny bubble for $4. something. (equates to close to $1000 /kg!!!)
    I have recently tried good ol' Lanoline grease (the green stuff) ... its dielectric properties are as good as the Permatex stuff at a fraction of the price... Also used it on my LS1 commodore ... excellent results
    May 2008
    thanks guys... luckily I read the label on the box that said not to adjust the gap...
    will get some grease tomorrow
    currently doing stage 2 of tightening head bolts... another 90deg yet!! I don't like this bit.
    Paul
    Central Queensland
    $26 for a platinum tipped plug? wtf?
    sheesh, and to think i fitted double platinum tipped AC-delco plugs in my XR8 last weekend..... and only $6-something each.... gotta love staff pricing lol
    the AC-Delco platinum tipped spark plug is #41-800, pre-gapped to 1.12 mm and available from your local friendly Holden dealer, i'll get a price for you on monday
    Central Queensland
    the AC-Delco 41-800 retails for $8.80 at work
    May 2008
    Quote Originally Posted by Sprint View Post
    thanks for rubbing the salt in
    Paul
    I use NGK Iridium BPR5EIX
    says it has 0.9 mm gap
    Usually around $20 each
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
