5th September 2009, 11:28 PM
Clutch problems....
Hi Guys,
In the process of putting a new clutch in the defender (td5) I noticed the slave cylinder rod stayed in the extended position after the clutch pedal had been depressed. It is possible to push the rod back into the slave cylinder how ever this requires reasonable force and once released returns to the extended position. Is this a problem with the Master cylinder and if so what is the cause.
Thanks Ben…….
