Results 1 to 6 of 6
Thread: Diff lock hassles
    Diff lock hassles
    G'day,
    My Stage 1 (Isuzu/ser 111/LT95) has for the first time refused to disengage CDL. It has always been rather good (better than my old rangie) with instant engaging and prompt disengaging (although always required a change into high range first). I have tried all the tricks that i used to need with the Hange-Over, s-turns, reversing, gently pushing against the handbrake etc. No joy
    Any advice before I jack her up?
    P.s Has anyone got rid of the vacuum system and used a mechanical system (I can dimly recall that my RAAF landie didnt have the vaccum)
    Melrose SA
    I am pretty sure the military ones use the vacuum actuator.
    I had this happen once and the diaphragm was stuffed enough to get it engaged but not good enough to disengage it.
    All this on the 80 Mile Beach in WA ended up using the air compressor to disengage it.
    parts then
    Anyone have a spare actuator up their sleeve?
    Melrose SA
    Dont skimp on it there is a well known business in Melbourne that sell reco ones the last one of those I fitted lasted 12 Months.
    The previous one lasted 20 years or more
    diff lock vacuum hose
    Any advice on where to get/ what to use for vacuum hose?
    I've removed the vacuum actuator off mine and am half way through making a lever to do it instead. Unfortunatley I damaged the actuator removing it.
    There is at least one more person on here who has removed the vacuum set up as well.
    Rgds
    Pete
