You'll end up putting huge stress on your drivetrain. the smaller tyre will drag. old man had to drive around in a freelander because disc was getting fixed the rear tyres were screaming couldn't figure out why until he looked at the sizes.
I am about to replace the 130's tires and wanted to go to 255/85 16 which seems to be the right option, but right now i have 265/75 16 and wanted to use the 2 good ones as spares. Logic tells you that the width is the big issue. By this what i mean is if you have to put the spare on that axel would mean that you have tires of differing dimensions, would this do damage? i know that on trucks you should not do it, is it the same on fenders?
mal
 Fossicker
						Fossicker
That;s a fair bit of difference. Here's some stats:
Tyre 1 - 265/75R16 >Tyre 2 - 285/85R16
Section Width:10.43 in 265 mm Section Width:11.22 in285 mm
Overall Diameter:--Overall Diameter:31.64 in803.65 mm Overall Diameter:35.07 in890.77 mm
Sidewall Height:--Sidewall Height:7.82 in198.62 mm Sidewall Height:9.53 in242.06 mm
Radius:--Radius:15.82 in401.82 mm Radius:17.53 in445.26 mm
Circumference:--Circumference:99.39 in2524.5 mm Circumference:110.1 in2796.5 mm
Revs per Mile:-Revs per Mile:657.3 Revs per Mile:593.0
Hmmm - the formatting didn't copy nicelyGo here to see in the proper format: http://www.1010tires.com/tiresizecalculator.asp
Unfortunately the sizes compared weren't the same as the original post:
Tyre Difference Comparision
Select Wheel/Tyre 1 / R 255/85 R16
Select Wheel/Tyre 2 / R 265/75 R16
Results for your selected Wheel/Tyre 1
Rolling Radius 419.95mm
Circumference 2638.62mm
Diameter 839.9mm
Wheel Cover Size Size 009
Results for your selected Wheel/Tyre 2
Rolling Radius 401.95mm
Circumference 2525.53mm
Diameter 803.9mm
Differences between Wheel/Tyre 1 & 2
Rolling Radius -18mm
Circumference -113.09mm
Diameter -36mm
When your speedo reads 100km/hr you're actually at 95.52 km/hr
Not quite true. Even at 100 KPH the different tyre sizes will cause the rear diff hemisphere rotation of 1.07 revolutions per second. This is not enough to cause inadequate lubrication of the hemisphere shafts, planet, spider gears. The centre diff will be even less worked.
It will test the limits of the V.C. type transfer case used in 89 and later Rangy's.
As for a freelander I am not familar with its drivetrain.
