Results 1 to 8 of 8
Thread: Speedo/ Gauges and dash question
    Northern Midlands, Tasmania
    I've dismantled my dash and have found that the gauges were cushioned in their holes by a now perished rubber/foam material. Were these a special seal or should any appropriately sized O-ring be sufficient?
    Also, some of my guages seem to have suffered over the years with condensation and or water leaks. Can the guages be serviced or is it better to just buy a new one? Can anyone recommend a good supplier?
    Thanks,
    Matthew
    The seal is a special part, almost certainly unobtainable, but the correct diameter O-ring would be perfectly satisfactory - and you may even be able to get a square section O-ring. Thickness wants to be about 1/16" or 1.5mm but is not terribly critical. Try any seal/bearing place.
    I do not know of anyone who refurbishes instrument dials - some people have done it themselves though.
    Thanks JDNSW.
    Where in NSW are you?
    Speedos
    There are a few guys who will do speedos- I have used two different ones in Sydney and one in Carrington (Newc). Can't recall the names off the top but I found them in the Yellow P.
    Yellow pages
    Namiiss Gauge & Control
    66B The Ave Wickham NSW 2293 - get directions
    ph: (02) 4961 1988
    2
    Advanced Automotive Instrument Co Pty Ltd
    Unit B1, 77 Carrington St Revesby NSW 2212 - get directions
    ph: (02) 9792 7399
    A.T.Electronics
    6/ 11-13 Rhodes St West Ryde NSW 2114 - get directions
    ph: 0425 246 424
    ETC ETC
    Quote Originally Posted by korg20000bc View Post
    Thanks JDNSW.
    About 60km outside Dubbo.
    Cessnock NSW
    G'day All, I can vouch for NAMIIS ('spelt correctly??) as I have used their services for the last 10 years, they can fix S2/S2A capillary temp gauges and speedos, cheers Dennis
    Jan 2008
    Brisvegas
    Or you could try a forum member.
    JohnR
    CC
