Have you tried disconnecting the battery and then reconnecting? See if it resets something? I wouldn't have thought the AFM would use enough power to make a "spark" sound. Sure somthing else isn't dead?
I put the new stepper motor in turned her on, idled like a dream, still spluttered out the exhaust but constant idle.
Turned off engine put the new AFM on, beautiful purring exhaust at constant idle. Pulled the AFM plug off there was a sound like a spark jumping engine died.
Put the plug back on, started engine and was back to the old spluttering exhaust.
Was I an idiot to pull the plug from the AFM while the engine was running? (I got the advise from this web site as a way to check the AFM was working).
Have I just killed my AFM, and am I going to have to get another one?![]()
1974 Military Lightweight Landy --- Some dementia at 50 years old
2000 Disco series 2 now sadly moved on!
No5 Trailer joined the fold... Awaiting graduation to road licensed!
2021 Mazda BT50 or is that DMax?
All seems OK.
I pulled the battery lead went for a coffee. Started her up - a bit lumpy through town. Drove to Liverpool and now she is sweet as a nut
Lets hope it lasts....
Not a good idea to pull it off when powered. Same goes for idle solenoid and anything else direct connected to the ECU as you can spike it.
Shouldnt have to pull battery lead, just unplug the ECU and leave it for a few minutes then re-connect.... ignition off of course....
Andrew
