I adjusted the airflow meter on my hotwire 3.9 after work thisafternoon. I took the plug off, checked it with the ohm meter and to my suprise it read
62Ohms, i i adjusted it back up to 300Ohms where it is supposed to be and for a start it no longer leaves a black circle on the wall from the exhasut, and it seems to run fine, much the same if not a slighlty smoother idle with the a/c on, but one downside is i don't think it has as much acceleration so tommorow im going to have a tinker and maybe bring it back to 150-200Ohms and see if i get some acceleration back. Would be interesting to see if i get better fuel consumption which i dare say i would.
Last edited by It'sNotWorthComplaining!; 10th September 2009 at 07:27 PM. Reason: error
From memory you do it engine hot, but not running.
All you are doing is turning a potentiometer. You aren't actually measuring any airflow, just a resistance value.
yeah i know how it all works i have resoldered circut boards etc in them b4 and adjusted them and yeah i did it engine at O/T not running and it is going great took it for another drive and the exhaust is alot cleaner so it's definatly made a positive difference.
You adjust it connected. Hot or cold makes no difference as does running or not running but ignition must be ON.
I do mine running and adjust it to 1.3 - 1.5V.
Adjusting it on a resistance value isnt accurate as its a voltage thing to get it right.
Pull back the cover on the plug with it connected and put test leads into the blue/brown trace (-ve) and red/black trace (+ve).
When running, changing the +ve test lead to a different wire, you can find the signal back to the ECU and by giving it a few revs, will see the voltage fluctuate with the increase in airflow resulting in the cooling effect on the wire. This is a good way to check the meter is working correctly.
Spose everyone wants me to put it on Youtube now to see it being done.....![]()
well it must be 6 to one half a dozen to the other it is 1.2 volts close enough for me.
