Results 1 to 10 of 17
Thread: clutch bleeding
    Nov 2008
    on the move
    clutch bleeding
    Here's the thing, since I got my Disco a year ago, the clutch has never felt right or more to the point the pedal.
    Works fine, no slip. it's just that it take up early from the floor so you have to depress the pedal all the way to the floor to fully disengage.
    So all was good in the world till I drove my cousins Disco, lo and behold his clutch feels great in comparison to mine.
    In our infinite wisdom we decide that maybe all it needs is a bleed.
    Note: we both know our way around mechanical things and are competent at bleeding brakes and clutches.
    We ended up almost losing the clutch altogether, we got a fair amount of air till it was only oil, then it was all down hill.
    So we then reverse bleed the system, small improvement. BUT, not as good as what we started with.
    To cut along story short, we got the clutch back to being drivable but we had some drag, so I'm thinking we are up for a new master cylinder.
    I have then driven back to Hervey Bay from Brisbane, parked, got up the next morning gone to work, what do you know, the clutch has improved.
    Three days later and the clutch is now back to it's good old self and exactly how it was before we started.
    Note: there is no fluid leaks any where and the level in the reservoir has not changed.
    WTF is going on?
    At $350 for a new master cylinder, I'm not rushing out to buy one if I don't need it.
    Ok Tech heads, your thoughts please.
    Cheers Lionel
    Feb 2009
    Pretoria, RSA
    Nov 2008
    on the move
    Quote Originally Posted by Rudolf View Post
    Just curious Rudolf, did your clutch pedal return to the top of it's travel or did it sit lower than the brake pedal with the broken spring?
    Mine works fine, just there is no resistence for the first part of the travel.
    A broken spring could be my problem as it would explain the piston not returning all the way in the master cylinder body.
    Cheers Lionel
    check the flex hose.
    Feb 2009
    Pretoria, RSA
    Quote Originally Posted by Gold_TD5 View Post
    Cheers Lionel
    Travel was normal but the feel was very light.
    Nov 2008
    on the move
    As in the hose from the reservoir to the master cylinder?
    Cheers Lionel
    Aug 2008
    N,E Vic
    All the hoses can brake down inside and cause problems.
    I use copper grease on all bleed nipples to stop
    sucking air.
    Andrew
    yep the flexy one thats down on the slave cylinder.
    It may be internally delaminating. Its supposed to be replaced with the brake lines (every 2 years ish) but usually isnt.
    May 2009
    Tatura, Vic
    Lionel,
    Is the master cyl push rod adjustable? I have seen many a vehicle with adjustable push rods causing a problem similar to yours. Sometimes adjusted too short or the lock nut has come loose they self adjust.
    Dave.
    Feb 2009
    Pretoria, RSA
    Quote Originally Posted by AKW View Post
    sucking air.
    Andrew
    On the slave I used teflon tape.
    Was the only way I could get the system to blead.
    Also see my reply with the link.
    The master cylinder is not adjustable.
