Results 1 to 10 of 24
Thread: Nissans might have strong axles, but pity about the wheel studs...
    WA
    Driving south on the Kwinana FWY, a GU patrol passed me - looked to be set up for touring and fully loaded.
    Got about 100m in front then pulled over quickly and put the hazards on. A truck in the left lane also pulled over.
    Turns out the GU had lost the left rear wheel - studs sheared. Which had then hit the truck...
    South East Tasmania
    Bugger, if it hapens in a populated area it may have hit a pedestrian
    There is not a vehicle that do not have a weak point on it. I think that the Toyota vans have the same problem with the studs.
    Adelaide - Torrens Park
    In my experience sheared studs usually have an underlying cause.
    For example, nuts overtight, nuts loose, etc.
    Adelaide Hills - SA
    I've always like the Land Rover alloy rim wheel nuts. About half a kilo of metal in them
    Compare a LR wheel nut to a Jeep's or a Toyotas. They all look puny in comparison.
    Melrose SA
    18 year olds at the tire shop with a new found love for rattle guns and wrong torque bars.
    Rangier Rover Guest
    That is not a one off I can tell you. The exact same thing happened to my neighbour wile he was booting it down a hill so could make it up the next hill in effect. Lost the rear wheel wile on the down hill so was hard for him to keep it strait. Had a very wild ride indeed.
    This one had standard tyres and rims. Stock as a Rock as they say. He's getting rid of it and buying a Disco.
    Rangier Rover Guest
    Quote Originally Posted by djam1 View Post
    I agree with this. I go nuts if any one uses a rattler on my stuff.
    With some Nissan's it is possible to miss with the rim to hub very slightly and can cause failure.
    Adelaide, SA
    Same thing happened to a friend in a 60 series landcruiser. Driving down a freeway at a 100km/h, he found one of his rear wheels overtaking him after applying his brakes.
    He said it was apparently a common enough problem on the 60 series?
    When I was using FJ40 and 45 Landcruisers in Central Australia in the sixties it was so common we carried a dozen wheel studs and nuts in the glovebox of each vehicle. You check them regularly and replace them as you go, that way you don't lose wheels. I remember I replaced four studs driving from Alice to Brisbane.
    Rangier Rover Guest
    Interesting that... We have the same failures with our 45 series here They also chew out the drive flange bolts
