Results 1 to 10 of 12
Thread: outboard stripped spark plug thread
    Jul 2007
    Just bought a new(old) boat with a old v4 Johnson 60hp on the back. pulled one of the plugs out and found the plug has been cross threaded or over tightened and has striped the thread. Is there any way to fix this or is it time for a new head? Also if anyone has one of these motors could you please post a pick of the throttle linkage set up under the cowl as mine is missing. Model number is VX13A and guessing it is of a 1970's vintage.
    Central Queensland
    helicoil?
    in the wild New England, NSW
    Your local tame head reconditioning service can probably helicoil it with the engine in situ without even dismantling...............
    ... take it in on the trailer...
    Hay Point
    Quote Originally Posted by Sprint View Post
    helicoil?
    X2. No need for a new or reco head. Helicoil will make it as good as a new one.
    Helicoil it, ITs a DIY process if you want to buy the gear and shouldnt cost you more than about $70 if its easy to get at to have a mechanic do it.
    There are also special helicoil like repair kits for spark plug threads, I think they are a little cheaper than the standard Helicoil Kits.
    Paul
    mike 90 RR Guest
    Quote Originally Posted by Randylandy View Post
    I have the V4 135hp / 1975 vintage ... plus have a FULL repair manual on most of these motors ....
    If you could post up a pic of the motor with the area of missing linkage ... I can send you an appropriate picture in response
    Mike
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    We have an old johnson 70hp if thats any help?
    P.s, can someone explain what ''helicoil is?
    CHEERS TIM.
    Eidsvold QLD
    so if you do the head in situ, how do you trap any swarf?
