G'day.
I am finally setting up my EEE PC laptop as a GPS, using Ozi explorer
software.
I have many of the digital mapping discs for around Oz but there is not one for the Mackay region.
I need one of the local area to practice and learn to use this GPS thingy.
Can I scan a paper map and then use it with Ozi explorer ?
If so what format do I save it, so that the software can read it ?
Tar.
Download a FREE 1:250K map for the area you want from Geoscience Australia
https://www.ga.gov.au/products/servl...EFINE_PRODUCTS
you will need the ER mapper ECW file and then have to import it into Ozi.
Getting your first map is a bit painful, but pretty simple from then on.
(It's all above board, courtesy of your own taxes)
Martyn
1998 Defender
2008 Madigan
2010 Cape York
2012 Beadell, Bombs and other Blasts
2014 Centreing the Simpson
VKS-737 mob 7669
Thank you, I'll see what i can sort out.
Cheers.
