Originally Posted by
isuzurover
I would be cautious about doing that - it is often hard to keep the oil in at the best of times. However the theory is that you supply a few psi of pressure (enough to overcome the pressure of water at design wading depth) to the diffs from an air compressor.
Some unimogs have pressurised axles etc...
You don't need much pressure - roughly one psi is equivalent to two feet of water - so 1.5psi should be enough and 2psi plenty.
