Thread: 101 Front Seats
    May 2009
    Cornubia
    101 Front Seats
    After 4 months on the forum just found this section
    Looking at more comfy front seats that mil spec for the 101.
    Save reinventing the wheel has any got any clues or words of wisdom.
    Peter
    Jan 2008
    Nowra NSW
    Hi Peter.
    This site is a weath of information which us F/C nuts have put togehter and much better than those other sites.
    My 101 has non standard seats.
    I believe the original ones were the same as series rovers.
    Mine are Sable brand and fit and work well.
    The problem is you loose a little bit of room from the seat to the steering wheel.
    If you are a little bit on the big side it will be important.
    What ever you fit must be thin profile.
    Some 101 owners remove the panel holding the spare wheel from behind the drivers seat , and that gives you room to fit what ever sort of seat you want.
    The spare wheel is relocated to one side at the rear of the tray.
    Jan 2008
    Nowra NSW
    I have been trying to find some pics of my seats.
    This pic is the passengers side and show the battery isollating switches and the retractable seat belt reel location.
    Jan 2008
    Nowra NSW
    This is the sort of thing which might fit.
    These seats came with my 101 for use in the rear.
    They were imported from the UK.
    Jan 2008
    Nowra NSW
    If you look at these pics carefully you will see one looking along the tray to the front.
    Note the spare wheel location on the floor and not up behind the drivers seat.
    I can only guess the alloy panel which use to hold the spare has been removed for a non standard seat and a tall driver, to get the room required.
    Also note the tanks above the rear guards on each side.
    Australian 4WD Monthly dedicated to 4WD, 4x4, SUV, Truck, 4 wheel drive and off road community, loaded with tips, tests, reviews, travel, gallery and forum
    Peter,
    I also feel your pain as well - I go numb after about an hour. As`Ron said what seats you get need to be relative thin as his 101 is a tight fit for my voluptuous figure .
    In understand that county/defender seats go in well - attached is a pic of a 101 with defender seats.
    Jan 2008
    Nowra NSW
    Garry has nailed it.
    I own a Defender and the seats are thin and surprisingly comfortable.
    I would think the seat runners would be a straight bolt in fit to a 101.
    The defender seats were designed to replace the earlier series seats and to fit in the limited space of a old series design.
    You also need a seat which the back tilts forward to allow maps and stuff to be stored behind the seat as the 101 doesn't have a glove box.
    The defender seats flip forward as required.
    Defender seat seats have a removeable bottom cushion......but that is not really a advantage on a 101.
    Jan 2009
    sydney
    Smile
    nice piece on montys 101 probably the best 101 around
    and he is such a nice bloke good to know about the seat thing "do they come in green?"
    Who is Monty?
    May 2009
    Cornubia
    Thanks all for the input, appreciated. Defender seats definitely worth a look, they might even allow for my fat singlet!
    Glove box???? I knew I had something missing, another problem solved.
    Thanks,
    Peter
