Try a hex socket rather than a 12 point. If you have done this already you may be able to remove the other bolts and GENTLY twist the shield in the direction required to undo the bolt while, at the same time trying to loosen the bolt. If your sockets are worn dont foreget to try a ring spanner.
Failing this you may have to cut it off.
No, exhaust gas will not come from this hole.
