Thread: New Windscreen
    New Windscreen
    Yesterday I had my second new windscreen fitted.
    While the guy was trimming the old sealant from the frame
    i noticed a cut wire on the drivers side pilar I asked if he don it
    but a closer inspection showed that it had been cut for a while,
    it must have been done when it was replaced at the panel beaters
    last year. The little speaker on the drivers door now works as the
    guy soldered it up while the screen was out.
    Moral to this is if you get a screen replaced in a D3 keep an eye on
    them as they trim off the old sealant as the wireing loom is very close.
    Bigmac
    Cardup, West Aust
    Thanks for the tip. About to get mine replaced. Just waiting to find out if our corporate insurance policy covers windscreen replacement, otherwise an expensive little job.
    Cameron
    If in doubt, throttle out
    MY16 RRS SE SDv6
    MY16 Ranger XLT
    2008 911 GT2 - dream came true
    1976 Escort mk2 - race car
    Sydney, Australia
    Make sure they replace, not re-use the clips that hold the A pillar trim on or you can llose them.
    Quote Originally Posted by CaverD3 View Post
    Yes, I have some 100mph tape holding down my lhs trim, which wants to blow off everytime a freightliner passes the other direction...... most annoying. (trivett's - alexandria)
    Aug 2008
    Adelaide SA
    Even with new clips, they can still fly off. I have secured the lower end of each trim with a small hole and a zip tie and no probs since. The ties are down below the bonnet line so not easily seen.
