Results 1 to 10 of 25
Thread: air suspension question
    sunny Hobart
    Talking air suspension question
    quick question about the air bag suspension on the D3
    1. is it self leveling when towing/loaded
    2. is it manually adjustable by the driver
    3. or does it auto adjust dependant on TR setting / vehicle speed / and when parked does it lower itself automatically
    thanks in advance
    Nov 2007
    Melbourne, Vic
    Yep,self leveling. Even the weight of a passenger can change it.
    Can normally be adjusted by the driver to only to different heights, access, normal, extended.
    Apparently there is a high speed height as well
    Melbourne, mostly
    Search this forum for much more on the settings, it's a faq.
    Answers not recently covered include:
    1. yes it does auto-lower over time, wakes up every 6 hours to level itself.
    2. TR does not auto-adjust the height, but the car will recommend raising in at least Grass Gravel, and will not engage Rock Crawl unless already raised
    3. the adjustment by the driver is only height, not rake (difference front/rear)
    4. yes it does drop by 20mm over 160kmph or something like that.
    Sydney, Australia
    And drops autmatically from off road height to normal at 40kph.
    It bongs at 40 and drops at 50 km/hr.
    sunny Hobart
    Quote Originally Posted by Desert Traveller View Post
    umm, would that be inappropriate in some circumstances....can that be over ridden before you dump 2 tonnes of metal moving at 50klm/hr on its belly
    I know that certain tracks can have a fairly high centre and the last thing you want is this happening
    Sydney, Australia
    Sorry, bushwanderer is right I think.
    No, drops just as you reach the base of the dune you need momentum to get up.
    Also drops on deeply rutted tracks and damages the underside.
    Nanny steps in because she thinks she knows what is best for you.
    sunny Hobart
    Quote Originally Posted by CaverD3 View Post
    bugger not sure I want that happening
    That sounds like an old Cypress Hill song
    sunny Hobart
    Talking are coils an option
    okay, so I dont want a D3 that has a mind of its own when it comes to dumping itself on its belly at undetermined/inconvenient times......
    so, I am thinking a coiler would be the only option but do they come with all the goodies of TR????
