Originally Posted by
trobbo
Was replacing the oil cooler lines today in my 95 D1 v8.
As I was tightening up the oil line that bolts in just behind the oil filter it was getting tight then all of a sudden went loose.
Bugger what have I done.. so I start to undo the nut and it unscrews ok and is not cross threaded. Start doing it up again and same thing happens. Have a closer look with the oil filter off and the nut that the line screws into has cracked and opens up as I screw the line in.
so can this unit be replaced or do I have to try and get the nut welded back together or is there something else I can do.
oh yeah, with the line at it's tightest point oil still sprays everywhere so I cant drive it.
Sounds like the timing cover has cracked. This will need to be replaced as it is almost impossible to repair it. Can you post some pics? I have seen this before, so isn't that unheard of. PM me if you need a timing cover
JC
