Results 1 to 10 of 14
Thread: Air suspension fault & a flat tyre
    Coming home from the GCLRO weekend at Levuka this arvo I encountered an "air suspension failure". Whilst driving through the road works at Park Ridge at 60kph the red warning light came on, bells ringing, etc, the D3 squatted down and panic set in. Nowhere to stop safely so I trundled along for another 500 metres 'till I could exit.
    Turns out the left rear was flat thanks to a nail I'd picked up. Unload the car to get to the spare, get the jack out and find the D3 would not got to normal height let alone off road height (required for jacking) which meant I had to use the scissor jack in lieu of the bottle jack as it wouldn't fit under the chassis rail.
    I suspect the car faulted the air suspension due to the flat on a fully-laden car which it could'nt "level"? In retrospect I think I should have removed the key for a minute of so and tried starting her up again to access off road height for the change.
    Anyway, changed the tyre and off we went, no problems at all.
    Remind me to buy shares in your local tyre company. With your luck in tyres they'll be making a decent profit from you!
    Turns out the tyre is buggered. $400 down the gurgler (again).
    Jun 2008
    Try HT+s only 315 each fitted saving you heaps, at ;least a round of ice creams for the family.
    Seriously you are using the car for what its designed for, enjoy and happy touring,
    Ryall
    WazzaACT Guest
    I had a very similar problem. Turned the car off to think about it and when I put the key back in the car went back to normal height.
    Brisbane,Qld.
    Hi Mark,
    Don't you hate it when a good tyre is stuffed? I think I am still outdoing you though - I have gone through four GGs now. All with sidewall damage so they are not repairable. A real pain. I have to get some 17s, I have to get some 17s, I have to get some 17s..........
    Tim.
    Gumnut - 1953 Series I 80"
    Poverty - 1958 Series I 88"
    Arnie - 1975 710M Pinzgauer
    d3viate Guest
    I too had a flat last week out the back of Nullagine/Newman on a one lane track with steep sides. The vehicle thought it had a suspension fault and promptly squatted itself down upon the 17" tyres bellying itself as I was on the edge of the track ( shaking hands with the unemployed at the time!) and unable to move the car to the centre of the track. After a frantic Sat phone call, found out you have to close and lock the car, unlock and restart to reset the suspension. LandRover emergency call centre a major topic in poor service in itself ! And that scissor jack, who was the idiot that ticked that as the jack. HiLift to the rescue luckily, as you stated no bottle jack fits under in this predicament. Does make you wonder how much offroad driving the LandRover engineers actually do.
    Quote Originally Posted by d3viate View Post
    Would an exhaust jack have worked ?
    (I actually used mine yesterday to lift a camry which was grounded in its home driveway, we only had 2 inches to work with....
    Quote Originally Posted by gps-au View Post
    I've never used an exhaust jack but there are people of forum with them and they sound like the sensible thing to have.
    My concern with them is the jacking point. I assume that as an air jack has a wide contact with the vehicle when jacking (what, 300mm diameter?) where do you place it under a D3? You couldn't use the (official) rear jacking point as next to the chassis rail is the compressor which is held in place with a diecast alloy bracket which is easily broken (from personal experience mixed with some stupidity)
    TO be honest, not until I bought one only a few weeks ago had I bothered. Now that I have used one, I wouldn't be without it.
    Thanks to CaverD3 for pointing out a few things under my D3, For those who haven't had a good learning look, do it.... Yes because of the wide footprint of an exhaust jack, the problems of placement are less, but a little bit of knowledge can save some grief later. (I do know now where that compressor lives )
