Results 1 to 3 of 3
Thread: Disco PAS box in county???
    WA
    I fitted a disco 4 bolt PAS box in the county on yesterday, in place of the original 4-bolt PAS box.
    The input shaft on the new PAS box appears to be about 5mm shorter, so I can't get the pinch bolt in as-is.
    I haven't had a chance to investigate fully, but I thought someone may have solved this before. Am I likely to find some slack elsewhere when I undo all the pinch bolts, or will more drastic measures be required???
    Adelaide, SA
    I've got the same issue on my 120, but I didn't realise the Disco PAS box input shaft is shorter.
    Mine started out ~5mm out, but I just assumed I haven't pushed/jiggled the input shaft on far enough - its down to about 2mm now.
    I was going to try loosening the PAS box mounting bolts and retightening to get the extra 2mm, but will watch this thread with interest.
    WA
    Quote Originally Posted by Offender90 View Post
    Thanks Bojan.
    I think it is shorter - haven't measured yet. The original 4-bolt had a slot machined which is wider than the bolt - allowing some room either way.
    I already levered the box as far as I could in the right direction while I was bolting it up, so don't think there are any more gains to be made there.
