Thread: D2 SRS Airbag Light is on
    Hi All
    Having done the Oodnadatta Track and Palm Valley the SRS light has come oin permanently.
    Any way for a quick reset or to turn of the light.
    Want to keep warning lights clear if not important.
    Yass NSW
    Reseat the connectors under the drivers seat, these can make the light come on.
    Regards,
    Tote
    Oct 2007
    SRS Light on
    Also check the connection behind the glove-box.
    Thick yellow wire.
    Trev.
    Denmark WA
    And make sure to disconnect the Bat. when ur fiddling with things - don't want to set em off!
    1974 Military Lightweight Landy --- Some dementia at 50 years old
    2000 Disco series 2 now sadly moved on!
    No5 Trailer joined the fold... Awaiting graduation to road licensed!
    2021 Mazda BT50 or is that DMax?
    May 2003
    On The Road
    Quote Originally Posted by Tote View Post
    Regards,
    Tote
    X2.
    May 2008
    Albury Wodonga
    Quote Originally Posted by land864 View Post
    Hi All
    How do you know if its important or not? Perhaps the better question would be "does anyone know a place that has the proper diagnostic equipment to read and clear any fault codes?" Once you have the codes read, actually investigate the alleged fault and go from there...
    Apr 2007
    I am lost
    Regards,
    Tote
    AGREE 100% it happens to me especially after trips things get stuffed under the seat vibration/dust just unplug it then blow out and reconnect fiddle with connection s if nessary
