Thread: one speed a/c
    Nov 2008
    one speed a/c
    well to day off alldays my aircon fan speed only works on fullblast, the temp settings still work as normal, but the blower dont work on 1-2 but works on 3,
    im thinking fan speed resistor,, but since i havent come acrose this prob at work im hoping sumone elce has and no a fix for it, or eny idears,
    Central Queensland
    classic symptom of a dead fan speed resistor
    Near the Yarra Valley, Vic
    I think I've got the same problem; sometimes 3 speeds, sometimes none! The engine note still changes pitch on all 3 clicks but no blower.
    Is it an easy job to replace?
    Nov 2008
    iv had a qwick look for it,,, but can sumone tell me were the resistor is on a 04 td5
    Scarborough, QLD
    Also, whilst mine changes with each setting, the highest setting isn't high enough. Is this also a problem with the resistor?
    Nov 2008
    so this dose sound lik a bit of a prob with this cars,,, i did a serch an found nothing,,, but talking to ppl and there like yer mines dose that,,,
    Quote Originally Posted by stig0000 View Post
    thats usually the resistor pack, as mentioned.
    Quote Originally Posted by Ranga View Post
    the fans are pretty asthmatic, but this symptom matches a dodgy earth as well as the start of bearing failure. If it starts blowing fuses on the top setting but not on the first and second its the fan motor.
    Quote Originally Posted by markyc View Post
    thats usually the switch contacts not playing the game or the earth connection on the fan motor. Easys a relative term, I reckon its all easy in a shed class. its not too bad in a D1 either.
