Results 1 to 10 of 17
Thread: Painting interior of a house
    This might seem like a dumb question....
    but when painting doors, door frames and skirting boards....do you have to use gloss?
    I really hate gloss don't like finish and its a pain in the arse to apply being a more oil based paint.
    Also the doors etc in the house that we are going to paint are either stained or varnished (didn't look that close) just looked and saw they are all wood finish...(and not nice look either)
    would we have to sand these right back to paint? or can we just rought them up and paint over the top
    TIA for the advice
    South East Tasmania
    I used low shin on my last 2 houses (water base) Semi gloss is ok as well
    Just give a light sand to remove any scale or gloss patches and then if you like to have a pait surface that would last 10 years or more give oone coat of Tubmans 3 in 1 and then two coats of the finish paint.
    I used Dulux for the finish coats
    But what it is working for me not necessary wil be good for others
    Visit THIS page which it is very informative
    Jun 2008
    McMinns Lagoon NT
    As in lip?
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Quote Originally Posted by Stuuu View Post
    As in lip?
    could you imagine how long that would take
    Jun 2008
    McMinns Lagoon NT
    Keeping the lip gloss on while you painted?
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Back down the hill.
    The advantage with full gloss is that it's easier to wipe clean, worth considering on doors and frames, places that attract hands.
    With painting, 90% of the result is in the preparation.
    It is also of utmost importance that when applying paint, be it undercoat, primer or topcoat; matt, semi-gloss or high sheen, you get the sticky side to the area to be covered.
    Hope this has been helpful, remember to post photos, before, after and during; include painters.
    Don't save money and buy cheap paint. Expensive paint has more pigment and stuff so takes less coats to get a good finish. More expensive brands often also aply more easily, so make the job shorter.
    If you're painting gloss enamel you could try using an applicator pad rather than a roller or a brush - get the paint tray with the roller wheel to load the paint onto the pad. They give a really good finish more quickly than a brush.
    And, the one time I used waterbased enamel I regretted it, maybe it's better now.
    have no intention of using cheap paint.......already picked out colours in the dulux range
    its just that in the uk everything was glossed when it came to doors etc...and I just hate the look of it, it may wipe clean easier but I think I would rather something be a little harder to wipe clean then look tacky....because a shiney gloss to me looks just like that tacky..
    also we have always found when its time to paint again over a gloss...as it always is unless your going white but even then it always turned to an off white its a bloody bitch to paint over..and there is just as much or even more work in rubbing it down
    Mar 2009
    Derbyshire UK
    Dulux do satin gloss Lou,we use it keeps the colour and easy to wipe down.
    MickS Guest
    Lou, you can get water based gloss...cleans up in h2o and doesn't have the same smell that lingers.
