Page 1 of 10 123 ... LastLast
Results 1 to 10 of 96
Thread: Adding 2 stoke oil to your diesel
    Aug 2009
    Leicester UK
    Has anyone done this or heard of this, read the link
    Freel2.com - View topic - 2-stroke oil and diesel
    Very interesting
    scott oz Guest
    Having read the link but not being that technecial I'd be interested in members views on adding 2stroke to fuel in a TD5 motor.
    Look forward to responses
    Aug 2009
    Leicester UK
    Quote Originally Posted by scott oz View Post
    Is not a TD5 virtually identical to a TD4 but with 5 instead of 4 cylinders
    Quote Originally Posted by Crackerjack View Post
    Hmm, if we are talking of the kinematic viscosity of the oil, it should be stokes (same word for singular and plural as it's named after George Stokes).
    As it's usually measured in centistokes, wouldn't 2 stokes oil be pretty viscous?
    Where's Isuzurover when you need him?
    Avoca Beach
    Is not a TD5 virtually identical to a TD4 but with 5 instead of 4 cylinders. NO. TD5 is a development of LR diesel with unitary injectors. TD4 is a BMW 2 litre with common rail injection. Regards Philip A
    Aug 2009
    Leicester UK
    Has anyone tried this, I would be very interested to hear
    Aug 2009
    Leicester UK
    At the rate of 1:200 I don't think that is an issue
    Aug 2008
    Alice Springs
    Hi all,
    I'm going to give this a crack............300ml to 80lt in my 300tdi disco, it sounds like it can only help any diesel engine run cleaner and smoother.
    Regards to all Jim.
    WA
    Love your wit Ron! I think it went over most people's heads. It should Always be written with a capital S. And that is Sir George Stokes - probably one of the only worthwhile products of Ireland - apart from U2 and The Pogues of course. And yes, 2 St (Stokes) oil would be about an order of magnitude higher than diesel fuel
    I suspect that adding 2-stRoke oil increases the lubricity of the diesel by a slight amount. In Germany (and I think France), all diesel now contains a minimum of 5% Bio to improve lubricity. (Edit - just read the thread and it says much the same). However, running B10 or B20 should have a similar effect.
    scott oz Guest
    Mate what's B10 / B20. I just go to the same service station because I know the fuel is good and fill up. there's only one pump - no choice
    really interested in this topic.
