Results 1 to 10 of 17
Thread: How accurate are GPS speedos
    Sep 2006
    Northern Beaches
    My GPS has a speedo, but I have no way of telling how accurate it is. In theory they should be accurate, bit I'm not so sure.
    Jeff
    Aug 2009
    Leicester UK
    I treat my Tom Tom speed as being accurate, the way the satellite system works, the speed has to be accurate as it is constantly working out where it is and giving a distance between 2 points, therefore giving an accurate speed between those two points, all the speedos of the cars I have had it in are inaccurate by up to 4 mph.
    Quote Originally Posted by Crackerjack View Post
    Both our Subaru Foresters (2005 and 2009) read 118km/h at 110 km/h (by the GPS).
    My P38A is spot on at 110km/h.
    its accurate to the radius of the Dilution of position circle/sec
    IF your GPS has that feature enabled it will give you a circular error of position number express that per second and thats how far it can be out.
    since mine manages to get that down to under 15 cms on a good day I figure its pretty accurate.
    Melbourne, mostly
    GPS receivers are very accurate speedometers, provided that:
    1. You have a 3D fix (see the receiver's documentation)
    2. The vehicle is travelling at a constant speed on the flat
    there is no need to measure the time from point to point. That will be less accurate than simply reading from the screen, because there will be a position error on both start and end points, and a small timing error.
    The GPSR works out its speed by Doppler shift relative to the satellites, not by working out a position, noting a time, then doing the same again.
    Most vehicles' speedos are set by the manufacturer to over-read by 2-4%, eg you may be doing 110 but it would read 113.
    Back down the hill.
    Quote Originally Posted by rmp View Post
    Note 3d is a quadulation, not a triangulation, meaning it is comparing information from 4 sattelites.
    Melbourne, mostly
    Correct. The 3"d" is dimensions, not satellites. However, I don't say to use 4 because that would require an explanation of the different stages of satellite lock acquisition, and merely seeing 4 birds may not mean a 3D lock is acquired. If the 3D fix is shown then the speedo should be all good.
    TOWNSVILLE
    If your GPS can lock in to Land Base Stations and provides real time (kinematic) you will be OK, otherwise the GPS does not know how much in error it is, even if it displays an error reading.
    Regards,
    PeterW
    Jan 2009
    Bibra Lake, WA
    My 2001 Forester is absolutely spot on with my TomTom.
    Jul 2009
    Hobart
    Hi,
    I read some where that it is trilateration that gps works on.
