Looking at buying some second hand side bars (brush bars) for my 95 110 wagon. They are off a 120 model. Would they fit straight on, or are there differences between the 110 and 130?
 ChatterBox
						ChatterBox
						The 120 has a extra 10 inches welded into the chassis after the rear side riggers (B-pillar chassis mounts) - see pic below. If the side bars are not intergrated with the side steps, then you should be fine. If it comes with side steps attached, the sidesteps will be too short for a 110, as it is only a single cab.
Hope that helps.
Bojan
