woops, i forgot to mention , on the oil return inside the head, eg the oil gets pumped up into the cam via the bearing caps holding the cam, and then trickles out and spills over the valve springs, ect, then falls down and through the holes in the head, where the holes are, you will see a casting inprefection where the hole is there will be a small razor type cast left behind. take a die grinder with a 1/4 inch end mill and take the burs out and open it up, the objective is to alow the oil to trickle through the hole as soon as possibul and avoid a build up of oil. when the engine is shut off, you have a hot head and thin layer of oil on it , not flowing because the pump is off, then the oil bakes on from the heat, this causes the build up of sludge, a killer in engines, mine was full of it from pore serviceing from prior owner and dirt injestion. the oil flowing into the engine faster also helps with lubracation recurculation aspecaly in the event of a low oil situation. dont get carried away boring and all that , its just to help the flow.
i ported mine too, just a touch up to get the sand marks off the head ports. let us know how you go.
rember if you havent modified evrey thing and made it better,...... keep working on it....
