Results 1 to 10 of 14
Thread: Oil in the wires/ECU
    Aug 2009
    Brookfield Melb. Victoria Australia
    Hi all I just had a look at the plugs on the offending harnesses and good news no oil, (Discovery 2 TD5 built Mid 2002 120,000 klm). Have looked at all the threads I can find here on the subject and found one that suggested stripping the insulation off the wires before the plugs, then soldering a small part of the wire and redoing the insulation.?
    Wondering has anyone tried this and did it work?
    Am I lucky and Land Rover have fixed this on the 2002 model?? (knowing my luck this will be a NO! ??)
    Or
    Is this something to look forward to?
    Is a quick clean up of the plugs going to get me home?
    Is the ECU sealed so that the oil cant get in?
    Worst case senario would be ??? $$$$
    Andrew
    by then it should have had at least one replacement injector harness.
    if its had a replacement harness it should have had a modded on fitted that means in theory it shouldnt leak again.
    its a relatively cheap part and is all of an hours work to replace.
    That Im aware of the oil doesnt get into the ECU but falls out at the plug.
    Aug 2009
    Thanks Dave will keep my fingers crossed and hope it stays the same, We are going to be dragging a Van around the country soon and I'm just trying to do the preventative maintainance.
    We will buy you a beer when we get up your way
    Andrew
    dont panic on the oil in the harness fault for the trip, its not an engine stopper.
    spend the money on a coolant alarm/engine saver (see one of the flyby adds up the top)
    If Im about you're welcome to pitch up at my place for an overnighter on the way up.
    Aug 2009
    Will do when we get up your way. Fitted the coolant alarm yesterday (The one advertised on this site) and it does all it promised to do, got a discount for mentioning where I saw the ad, easy to fit arrived within a few days of placing the order. Used to have simular when I owned a truck and the alarm saved serious damage a few times.
    Now all I have to do is check the oil pump Bolt!
    Andrew
    johnclv Guest
    I got one - brand new - never used. You can purchase cheap if you want. PM me
    I was going to replace mine but ended up selling my Disco instead
    Aug 2009
    Hi new to this and not sure how to PM so give me a call on 0419567460
    Andrew
    South Yundreup,WA.
    Do a search on the site, there is plenty of information on this issue and how to deal with it.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    SW coast, Victoria
    Quote Originally Posted by adonuff View Post
    Or
    Andrew
    Won't hurt to carry a pressure can of ( non-residual) electrical contact cleaner ( ex Jaycar or Electronics store etc)
    If it starts to run rough ..like it is on 4 cyls... and wont "pull the skin off a rice custard" then oil in the harness is an obvious check.
    Spray the plugs clean and things will probably improve until it clags up again.
    Once oil travels down the copper wire inside the plastic shielding .. a loom replacement is the "only" option....ask me how I know.
    Bob
    South Yundreup,WA.
    Quote Originally Posted by discodancer View Post
    Bob
    Bob,
    Sorry but that is absolute rubbish and similar to a dealer sentiment, not criticising you as there are many that have been told the same. There are plenty of us on here that have had oil in the injector harness, into the main loom and through to the ECU plug and have not had to replace the whole loom. Generally the reason we replace the injector harnes is it is relativelly cheap and an easy task. The main loom is however an expensive item and time consuming to replace. There are several post on how this has been done, but basically you set up a container on top of the female lower plug near the head. Disconnect the ECU plug from the ECU and place a container underneath to catch the residue. A small plastic coke bottle is a possible use as it will push or thread in. Some good gaffer tape around it to seal. Then either cut a hole in the botle and pour in non destructive contact cleaner or even metho and allow to gravity feed through to the ECU plug overnight or put a bike car valve in the bottle, by removing the valve you can 1/4 or 1/2 fill the bottle through the valve, replace the valve and apply low pressure from a compressor or bike pump. Only very low pressure or you can create a missile. Once flushed clear liquid will be coming out at the ECU plug. You can allow it all to drain but contact cleaner is non conductive so should not be an issue so it can be run straight away. I just cleaned any residual every couple of days for a week and then checked it weekly until there was absolutelly no residue. Have not replaced the main loom and it has not missed a beat. Replaced the injector harness with a new one and cleaned up the old one as a spare (yes they do clean up and work), just need some new O rings and I will have a good spare if it happens again.
    Beware a lot of dealers or ill informed service departments will tell you it needs a new loom and if it is under warranty is not an issue, but if it is out of your pocket it can be a big expense that is not needed.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
