Results 1 to 4 of 4
Thread: 1999 TD5 EXtreme A/C compressor
    GY1688 Guest
    Angry 1999 TD5 EXtreme A/C compressor
    Does any body knows the 1999 extreme TD5 A/C compressor is made by who and where can I get a new one? As told by the A/C man the slow slow leak might be from he compressor but the compressor have no sticker on it but do have B 709U on the compressor body and the clutch have small number on it ABC92E. I am sure the A/C is from new car purchased. Have seen many other Defender have same compressor but can not find the compressor model number to get the parts. Perth L/R dealer wants AUD2300 for the compressor and have to get it from the East.The part number was given as JVP1013 but rang Jayair and ICE both can not find any thing match the number JVP1013. Is the Defender compressor normally leak?? I understand it is 10 years old car and might need to change. But must be able to find from DENSO or Sanden?? for the OEM.....or something that can use original brackets and pipes. ANY HELP PLEASE.
    Ferntree Gully VIC
    i'll check the brand on mine in the morning for you
    130's rule
    Kingston, Tassie, OZ.
    It'll be a Sanden SD709, with a multi V clutch pulley.
    Should be readily available.
    JC
    Last edited by justinc; 11th October 2009 at 08:00 PM. Reason: Sorry, got the 'D' wrong wasn't 'P'
    Brisbane, Queensland
    I have a AC compressor new in the box from a Defender TD5 air con kit I purchased from Land Rover. The model no is SD7H15. The AC compressor wheel doesn't suit my pulley so was planning to sell it on ebay.
    PM me if your interested, make me an offer.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
