11th October 2009, 11:15 PM
Warning light for Maxi dif lock
Can anyone tell me how to wire up a warning light so it is on or off in synch with the locker ?
11th October 2009, 11:29 PM
You should have two wires coming from the switch which is located at the actuator. One wire goes to earth and the other goes to the indicator light. Then you need to run another wire from the other terminal of the indicator light to a wire that is active (+12V) when the ignition is on.
When the switch is closed, the circuit will be complete and your indicator light will be on.
Roger
12th October 2009, 07:12 PM
Thanks Roger I'll see how I go with it
