Results 1 to 10 of 11
Thread: Disco vs Defender R380
    WA
    Does anyone have pics/measurements of the differences in the shifter position between disco and defender R380 boxes?
    NSW , Pennant Hills
    Hi Ben;
    can't help with the shifter position in defender , but possibly can with a disco R380 , as I have the centre console out.I can take pics , what exactly do you want me to take photos off and measure ?
    Jul 2007
    TD5 Disco R380
    TD5 Defender R380
    WA
    Quote Originally Posted by slug_burner View Post
    TD5 Disco R380
    TD5 Defender R380
    Thanks, that is pretty much all I need to know!
    So does the dingus from the Defender box bolt straight onto the Discovery box?
    Adelaide - Torrens Park
    Depends what a dingus is...
    Oct 2008
    Quote Originally Posted by BigJon View Post
    WA
    Quote Originally Posted by abaddonxi View Post
    I think he meant the extension housing and shift level/linkages.
    i.e. - is it possible to convert a disco r380 to a defender one and vice versa?
    Also - does anyone have a measurement of the difference in gear lever position?
    Sorry I don't have measurements for Defenders, but some for the disco that could help you make an estimate from the pics are:
    Length of main section of gear case is 240mm
    Length of extension case (for 5th and rev gears) is 146mm
    The disco lever comes out about 110mm (edit to fix typo) behind the joint between the main and extension cases. The lever has a crank to the rear and right - it is approx 50mm to rear.
    Edit: in the pic of Defender R380, the lever is close to being above the oil filler plug. This plug is 110mm behind the bellhousing joint.
    So the disco lever would be 240 - 110 + 110 = 240mm behind the filler plug.
    WA
    Thanks John.
    Any idea how easy it would be to dismantle the shifter assembly and change it so it was rotated 180 degrees?
    (there is always the option of cutting and welding if not...)
