Results 1 to 10 of 29
Thread: Cant take much more ! Overheating again and again
    Jan 2009
    Inner city Melbourne dreaming of the Lakes
    new radiator , new overflow, new thermostat, seems to last about 3 months in between these incidents of overheating, then bingo it happens again.
    I getting close to bailing on my first Disco ..does anyone have a genius mechanic in melbourne preferably north or east ?
    Narre Warren
    Is it a tdi? When it over heats is it using water?
    If so check around the water pump its pretty common for the tdi to develop a small leak.It took me a while to work out where mine was leaking from.
    If your over it try Roverland on Dorset Rd
    Jan 2009
    thanks for that its a V8i 1996 .
    Adelaide Hills - SA
    How's the viscous fan?
    Check out post #15 on this thread: Disco 1 overheating - help needed
    Safety Bay
    Quote Originally Posted by spudboy View Post
    With the engine at operating temp put a paint brush against the fan,it shouldn't change speed,if it does you have your problem. Pat
    It's a 3.9. It's possible you have a slipped liner.
    Is it using any water?
    If you have a borescope, you could put that down the spark plug hole to look. See if there is water in there or if the piston looks clean (although it might be if the head has been off).
    Steam Cleaned Piston
    If you pull that head off, run your fingernail over the liner/deck junction. It should be dead smooth. If there is any lip, I'd say the liner has moved.
    See these pix I took of a block I have:
    Good:
    Slipped
    Re block pressure testing, see
    [ame="http://www.youtube.com/watch?v=C2EyvgxdyRY"]YouTube - Land Rover Engine Block Leak Tester[/ame]
    Jan 2009
    And the prize for genius of the week goes to...SPUDBOY ! Not only does the paintbrush stop the fan but i can stop it with my fingers ! Thanks very much - will try Britparts for the new viscous.
    Cheers to everyone who took the time to reply
    Steve
    Adelaide Hills - SA
    Genuis of the week!!! I'll be telling my missus that
    Glad you got the the bottom of the problem.
    Quote Originally Posted by Avrio View Post
    Warning! Do not get an Allmakes VC.
    They lock up too much and drag a lot of power. Replacing my near-new Allmakes VC with the genuine item improved the 0-100km/h times by 5 seconds.
    Meredith vic
    re overheating
    If the viscous coupling is good and still getting hot take radiator to a specialist and get it rodded. if you are using anti freeze the glycol deposits in the core creating an insultating coating. A 10% blockage can cut your cooling by up to 25%. I run a corrosion inhibitor that does not have glycol. Y only need only need anti freeze if you are staying in the snow for an extended period. Glycol also eats gaskets and likes to find any leak! Call Dave on 0431300629 for any more info
